February 18, 2005, 07:26 |
Help on basic multicomponent problem
Hello everybody,
I am used to calculating single gaz flow but when it comes to multi-species, I am utterly neophyte. I've been reading FLUENT manual and have some questions after that. First, my problem, I have 2 entries, one MASS FLOW INLET of air, another MASS FLOW INLET of water vapour and a PRESSURE OUTLET. My problems are the following : - What should I enter in the field : Define>Models>Species>Mixture Template, knowing that I imported water vapour and air from the database? - How do I do to select water vapour and air for my 2 boundary conditions, knowing that Fluent asks me to chose between O2 and H2O only when trying to specificate the boundary condition? - What should I select as an option knwoing that I don't want any chemical reaction and would only like to simulate the exchanging of heat between the 2 gas? Thank you in advance for answering, even partially, my questions. Eduardo |
February 18, 2005, 23:46 |
Re: Help on basic multicomponent problem
After selecting any one of the available mixtures in species panel you can edit them in materials panel.If you dont want chemical reactions dont enable it in species panel.
Display Modes | |
basic fluid flow problem - is there a way to switch pressure to a flow rate in analyt | vlnikolic | Main CFD Forum | 3 | September 16, 2016 04:07 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
FSI problem , Help needed for my basic questions | kmgraju | CFX | 1 | July 29, 2011 00:04 |
Problem of mass conservation in multispecies flow in porous media and T° gradient | pilou | FLUENT | 0 | January 31, 2011 08:19 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
