February 9, 2005, 09:09 |
mass transfer in fluent 6.0.12 or 6.1.22
dear sir do u know could fluent handdle mass transfer from wet-solid to hot gas(for example: in fluidized bed dryer)without using of UDF? regards masood
February 9, 2005, 17:05 |
Re: mass transfer in fluent 6.0.12 or 6.1.22
there is not such a sir here but a bunch of people helping each other, you will get better results with UDF for a FBD, read the user manuals they're spread all around the web.
February 10, 2005, 10:57 |
dear someone!(or sir!) i said without UDF!is it impossible without UDF? regards masood
February 22, 2005, 09:14 |
rotating blades?
I modeling a flow through two blades revolving in a cylindrical geometry, the fluid is note rotating, the blades are used just as scraping of the walls in interior of cylinder, when I have a strong shearing, what do you suggested choose as solution of this problem, Reference frames, moving wall or sliding mesh?
Thank you. |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase Mass transfer UDF issue | therandomestname | FLUENT | 0 | April 21, 2011 14:51 |
free convective and diffusive mass transfer | rajani | FLUENT | 0 | July 27, 2005 08:28 |
