February 16, 2005, 09:08 |
Fluent blood flow BC
I am working on a project involving pulsatile blood flow simulations (using FLUENT) through Z stent device used to cure Abdominal Aortic aneurysms. I am able to obtain inlet boundary conditions, in terms of pressure profile and velocity, but I am not sure what to use for my outlet conditions. The device is about 17cm long and I don't have enough information about the variation in pressure and/or velocity along this short distance. I would be grateful, if anyone could suggest some solution. Thanks.
February 17, 2005, 12:19 |
Re: Fluent blood flow BC
Since the mean vascular pressure is 90 mmHg, and it is in AAA, I think you can assume the outlet pressure is 90 mmHg.
But I am not familiar with Fluent, I used FIDAP. Your question make me think another question: In FIDAP tube flow examples, why there is no oulet boundary condition added? or their default is the outlet P* is zero? |
February 22, 2005, 17:17 |
Hi. I am working on the pulsatile blood flow through stnosed arteries. I am curious as to what kind of pusatile conditions you use at the inlet (For eg. Do you use a sinusoidal velocity profile at inlet)? I have prescribed outlet B.C. as press outlet. But it does not seem to give me good results. Let me know if you come across something that works.
February 22, 2005, 23:00 |
i guess you use outflow boundary conditions, if you donot know the conditions at the outlet.
February 23, 2005, 06:51 |
I'm trying to imitate realistic flow profile for the abdomen region, which is looks like damped sinusodial oscillation. But i still haven't fully developed the model.
Display Modes | |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
How do I select solver options for external flow over an aircraft by fluent? | hadieliasi | FLUENT | 5 | May 2, 2011 03:54 |
Flow Development in Fluent | sth | Main CFD Forum | 0 | November 30, 2010 11:26 |
Oscillatory Flow in FLUENT | phy | FLUENT | 0 | February 2, 2008 10:19 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
