-   -   Rayleigh numbers?? (http://www.cfd-online.com/Forums/fluent/35840-rayleigh-numbers.html)
ocy February 23, 2005 22:43
Rayleigh numbers??
Hi all,
Is there a way to get Ra plot in fluent?
I have only managed to get Nu # plot.
Pls help. Thanks.
Michael February 24, 2005 03:58
Re: Rayleigh numbers??
Fluent has no possibility to plot Ra number directly. But you can esily do that. Use Custom Field Functions do define the Rayleigh number as a custom field sclar.
ocy February 24, 2005 04:41
Hi Michael,
Thks for reply.
Can you explain it in more details? Where is the custom field functions? How can i define Ra as a custom field scalar.
I'm new in using fluent, hope you won't mind.
Thks.
michael February 24, 2005 04:53
Go to define-> Custom field functions. There you can specify your function. After definition you can display contours of your defined function on selected surface. Good luck.
ocy February 28, 2005 03:19
Hi Michael,
do you have the function of Rayleigh numbers?
