urgent help in udf
Old   February 27, 2005, 05:13
Default urgent help in udf
Rama krishna
hi i want to maintain a constant temperature for a particular domain named hotpool in flunet can any one tell me the how to write the udf code for that using define_adjust (i think) please
Old   February 28, 2005, 05:40
Default Re: urgent help in udf
Andrew Garrard
If your temperature is constant, then why do you need a UDF?
If actually do need a UDF you could use something like
DEFINE_ADJUST(name, d)
cell_t c;
Thread *thread = Lookup_Thread(d, zone_ID);
begin_c_loop(c, thread)
C_T(c, thread) = your_temperature;
end_c_loop(c, thread) }
Old   March 1, 2005, 23:17
Rama krishna
thank you for quick response i will tell you my problem completely sir my geometry a is a heat exchanger which will be submerged in a hotpool of liquid sodium and the in let and outlet of the the heat exchanger shell are porus in nature. so cold liquid passes through the tubes and hot liquid comes in contact with the tubes thru the porus inlet. and gets cooled. so in order to maintain the natural convection current eaither i have to give a heat source boundery condition in the hotpool or i have to maintain the temperature of the hotpool constant for each and every itiration. so please kindly help me sir
Fluent (ANSYS12) UDF Help, PLEASE! Urgent! ANITIX87 FLUENT 21 April 12, 2011 03:55
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent! UDF error "implicit declaration of function" ivanbuz Fluent UDF and Scheme Programming 3 June 18, 2010 05:46
Urgent! UDF error "implicit declaration of function" ivanbuz FLUENT 13 June 17, 2010 18:11
URGENT ! UDF ERROR! Prateep Chatterjee FLUENT 6 October 16, 2001 19:20
