February 26, 2005, 16:56 |
Turbulence model for backwards facing step
Hello everyone,
I am currently investigating flow separation and re-attachment over a rearwards facing step. To date, I have been using the S-A turbulence model, because of computational efficiency, and in order to get a 1st order approximation of what I am looking for. My current task is to improve the turbulence model selection. I considered the K-epsilon model, but literature states that it does not accurately simulate the separated region with the reverse flow. Any suggestions? If I go to a Reynolds Averaged or a Large Eddy simulation, I doubt my computer could handle it ! |
February 26, 2005, 17:29 |
Re: Turbulence model for backwards facing step
Actually guys, thoughts on K-Epsilon with Non-Equilibrium wall functions would be appreciated.
February 27, 2005, 04:27 |
you may try v2f model. it can handle this problem better than ke and sa but requires some more comptutational resource than both of them...
February 27, 2005, 12:02 |
V2F - 4 equation, LES and RANS combined, right?
Am I correct in assuming it will take double the time of the 2-equation models, or will it take more? |
February 27, 2005, 14:58 |
it is based on rans. accurate tool for seperated flows and will cost slightly larger than a simple k-e model
you can find detailed info and test results and comparisons with k-e at: http://www.turbulentflow.com/ |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
turbulence model equation | Andy Chen | FLOW-3D | 4 | January 1, 2010 21:45 |
build your own turbulence model with buoyancy | Thomas Baumann | OpenFOAM | 11 | November 23, 2009 08:53 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
