March 1, 2005, 10:18 |
Mesh grading problem
I have a problem I made grading of my mesh and exported it to mesh file And then I forget about what value or what type of grading I used when I imported this mesh file back in gambit to check grading I used. I could not see the value in fact I see the default option. How can I check what value and what type of grading I used. Y
March 1, 2005, 12:41 |
Re: Mesh grading problem
You can only get that information from the original gambit file. If it's been deleted from the model, then you'll have to dig through the .jou file to try and find it. Other than that, it's a guessing game.
Jason |
March 2, 2005, 02:48 |
Perhaps you could go to the modify mesh icon in Gambit and you select(click) the egde then the values should appear. I have tried this before.
Sham. |
March 2, 2005, 05:47 |
I think it just shows you "sucessive ratio" everytime even if you have mesh grading. You can do this and check it with tut 23 case of backawrd step. I do not how to get this mesh grading with just *.msh file. Z
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Moving mesh problem | Geon-Hong | FLUENT | 3 | April 5, 2010 03:24 |
[GAMBIT] Problem with mesh. Please Help... | maziboss | ANSYS Meshing & Geometry | 1 | September 28, 2009 02:24 |
