March 8, 2005, 15:41 |
Periodic B.Condition
Hi Everyone ! how are you doing ? hope well. Iam trying to simulate the through compressor blade (in 2D), Using Gambit, I created the mesh around the blade, and when I tried to export to Fluent, it showed me that there is error in Periodic Condition, so , iam asking if there is anyone can help me to solve this problem. thanks in advance
March 9, 2005, 01:55 |
Re: Periodic B.Condition
HI
For the periodic bc. you have to link the edges (in 3d the faces) before you mesh them. The mesh has to be exactly the same on both sides if you want to use periodic bc by MATEUS |
March 9, 2005, 03:54 |
Try setting the periodic boundaries as two separate bc's, such as two symmetry bc's, in Gambit and then forming the periodic bc in fluent using the text interface as below.
grid/modify-zones/make-periodic Before forming the periodic bc check that the fluid zone's origin and axis are defined correctly under the boundary conditions panel. If this does not work, I'll need more info on the error message you're receiving from fluent. Hope this helps, Mark |
Display Modes | |
Periodic boundary condition | Arif | FLUENT | 3 | March 9, 2017 01:18 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 02:18 |
Why can't I make the boundaries periodic? | Alina | FLUENT | 5 | April 12, 2012 14:06 |
problem about periodic boundary condition in Fluent | winnawinna | FLUENT | 0 | December 28, 2010 23:32 |
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap | Josh | ANSYS Meshing & Geometry | 10 | July 8, 2010 02:39 |
