Home > Forums > FLUENT
error message from graphics func. Update_Display
Old   March 8, 2005, 15:25
Default error message from graphics func. Update_Display
Manish
I was able to open graphics window in fluent to dispaly grid, residues, x-y plots etc earlier, but now suddenly it stopped working.It is showing following error
"Error message from graphics function Update_Display: Unable to Set OpenGL Rendering Context
Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION). Error Object: ()"
Kindly help in this it has halted my project work . I am a student of Indian Institue Of Technolgy Madras(IITM)
Old   March 24, 2005, 05:40
Default Re: error message from graphics func. Update_Displ
Anand Odedra
I dont have any perfect solution of your problem but rather have a suggestion. I had a similar problem. Everything was running fine and suddenly FLUENT started giving me same error as you mentioned. Later I found out that this was because I installed new version of Matlab. When I uninstalled the Matlab everything was back to normal. So check if you have installed any software which is causing trouble.
Anand Odedra, PhD student, Loughborough University, Loughborough, UK.
Old   April 7, 2005, 08:15
Manish
Thanks,
I also found the same problem I uninstalled Matlab and now its working fine. Thanks anywaz.
Old   April 8, 2005, 04:38
Anand Odedra
Hi there,
I found another solution to that problem. If I swith of Hardware Acceleration of my computer then there is no conflict between Matlab and FLUENT. To do so on your desktop right click go to the Properties/Settings/Advanced/Troubleshooting and move the Hardware acceleration slider from Full to None. This has worked for me.
Cheers!!
Anand
Thread Tools
Trackbacks are On
ANIMATIONS IN BATCH MODE Arianna FLUENT 1 January 31, 2008 10:04
Fluent and Silicon Graphics workstation Swati Mohanty FLUENT 0 September 24, 2006 23:02
Graphics Problem Ryan FLUENT 0 January 18, 2006 10:57
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 11:15
Problem: graphics display in prostar main window Jiaying Xu CD-adapco 8 February 14, 2002 09:08
