Need advice on reaction in Turbulent Flow
Old   March 12, 2005, 20:01
Default Need advice on reaction in Turbulent Flow
Angelo Sozzi
I am encountering a weird problem with the fluid density in reactive flows. Problem: A + Radiation --> B in Water (liquid) With A and B properties (density etc.) like water.
The Hydrodynamic Flow with Fluid = H2Ois converged and OK. I add the reaction (see below) and suddenly the density throughout the domain is no longer 998kg/m^3 but 0.734 kg/m^3. Given that i have a massflow inlet this changes my speed from some 0.11-2m/s to over 6000m/s. I seem to have NO influence over the density, whatever I do, once the fluids are in a mixture template.
If you know what I might be doing wrong please let me know.
--------------what I insert ino the mixture----- Define-model-speciesModel: Species Transport * Finite Rate/Eddy Disipaton * Volumetric Reaction * inlet Diff * Diff Energy Source -- Define-Materials-Material Type Fluid use liquid water as basis and create the fluids A and B with the properties of water. - add A, B, Water-liquid to the species list (liquid water is last for bulk) and delete the rest -- Add a reaction A -> B (rate will be defined by UDF later.
iterate and voila density is down to 0.73 even though all three components have a density of 998 ????????
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
Reynolds and Turbulent flow Frederic Dubinski CFX 5 October 21, 2004 04:12
Reynolds and Turbulent Flow Frederic Dubinski Main CFD Forum 2 October 20, 2004 13:57
two phases flow with reaction dingding CFX 6 September 17, 2001 08:46
