Need urgent advice about Laminar flow analsys |
March 12, 2005, 10:12 |
hi,
I'm making a study on a body previously experimented in a wind tunnel. Firstly I'm making analsys for laminar flow but both coupled and segregated solver gives very high drag coefficient values. Lift coefficient is near but still very inaccurate. Segregated solver is much far than the coupled solver. But still there is a difference of about ten times. is this related with some parameters of the solver or the mesh itself? I have made courant number 9 at first and 5 later during the solution with the coupled solver but it didn't work.. So could anyone give me advice about figuring out the situation? Thanks, |
March 14, 2005, 03:01 |
Re: Need urgent advice about Laminar flow analsys
About the couples solver I suggest before iterating with the first order. Then change to the second order. Use the default Courant number (5). Then when evetuthing seems to be nearly converged you can raise the Courant number. The segregated solver is faster but I would use the coupled if the Mach number is high.
Display Modes | |
Turbulence model for Laminar flow | Terry | Main CFD Forum | 8 | August 14, 2010 05:45 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
Axissymmetric "laminar flow?" -> Calculation of Cd | Rahul Sangole | FLUENT | 3 | January 30, 2006 02:31 |
Unstructured grid problem - Laminar flow pipe | Roby | FLUENT | 0 | January 12, 2006 05:54 |
modelling laminar and turbulent flow in the same | Ol | FLUENT | 2 | November 25, 2005 02:52 |
