BC´s natural convection??
Old   March 14, 2005, 11:06
Default BC´s natural convection??
Thomas
I want to simulate natural convection in a simple chimney. I don´t want to use the boussinesq modell, as delta T is about 40 K. I have a pressure inlet at the bottom and a pressure outlet at the top. The sourrunding walls have a temperature condition.
How do I have to specify to density when I use the incompressible ideal gas law?
How do I specify the operating density? I´ve read in a tutorial that I should set the operating density to 0.??
Thank you for your help!
Thomas
Old   March 14, 2005, 12:11
Default Re: BC´s natural convection??
Evan Rosenbaum
I've had good results setting the operating density to the density at approximately the mean gas temperature.
Old   March 15, 2005, 02:33
Thomas
Did you use the the incompressible-gas-law or the boussinesq modell? So for example: Incompressible gas-law: Operating pressure: 102325 Operating Temperature: 288.16 Operating: Density: 1.225
As the opertation temperature is coupled withe the operating density, I think I have to adapt the density and temperature to my problem. Right??
Old   March 15, 2005, 12:08
Evan Rosenbaum
We have typically used a piecewise linear density for fluids and ideal gas for gases. You only need the operating density as a reference point for computing local buoyancy force, so the exact value isn't overly critical as long as it falls in your actual range of local densities.
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Natural Convection Problem - Helium marzoa STAR-CCM+ 0 April 18, 2011 14:12
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 18:43
natural convection in a sealed enclosure James Main CFD Forum 4 April 2, 2001 15:48
