March 14, 2005, 17:25 |
Mach No Contour
Can any one pls tell me how to see the mach numnber contour in Fluent. I dont see a mach number contour display. If we can generate one such by user defined programming, pls let me the steps in doing that.
Srivatsan |
March 14, 2005, 19:37 |
Re: Mach No Contour
Are you using ideal gas law as your air density in the materials panel?
March 14, 2005, 20:55 |
Re: Mach No Contour
I am using Ideal Gas! and compressible!
March 15, 2005, 07:44 |
Re: Mach No Contour
It is in the Contours Panel... Plot contours of velocity, and where it says Velocity Magnitude, select that drop down box and Mach Number is under there.
Jason |
How obtain a Mach number value from a case run with Xifoam solver?? | lfgmarc | OpenFOAM Programming & Development | 0 | June 15, 2011 03:00 |
Mach Contour on water vapor compressible flow | Tony | FLUENT | 4 | July 15, 2010 11:20 |
to plot Mach contour using GNUPLOT | killtimm | Main CFD Forum | 2 | December 28, 2009 11:15 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 12:48 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
