Home > Forums > FLUENT
dynamic mesh, negative absolute pressures
Old   March 15, 2005, 10:36
Default dynamic mesh, negative absolute pressures
Jason
I am setting up a 2D problem with a thin gap (~5 microns) between a moving block and a stationary wall (lubrication problem). I have set a high pressure and a low pressure on either side of the moving block. When I solve the problem for low velocities (0.1 m/s), things look reasonable. I've ramped up successfully to 0.7 m/s, but when I increase beyond that, I get negative pressures and very high velocities in the thin gap. Anybody encounter anything like this? Thanks in advance. -Jason
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
Regarding Negative volume detected in Dynamic mesh Vinay Morabad FLUENT 10 December 16, 2015 01:31
Negative volume in dynamic mesh Max FLUENT 1 August 7, 2006 05:18
Incylinder Dynamic Mesh Creating Negative Volume Sujtih FLUENT 3 August 1, 2006 15:53
Dynamic Mesh, negative volume! ROOZBEH FLUENT 2 June 22, 2006 20:51
