March 17, 2005, 15:54 |
Velocity Inlet
Hi everybody,
I have read somewhere that when entering text commands UDF cannot be used to define boundary conditions such as an velocity inlet although the UDF are used to define such conditions when using the GUI. Can someone confirm? Secondly, if this is true what is the alternative mean to define a time-dependent parabolic profile at the inlet of a pipe. Many Thanks David |
March 18, 2005, 02:23 |
Re: Velocity Inlet
Can it make it clear Y
Velocity Inlet BC -- Flow Reversal | salihovic | FLUENT | 0 | May 8, 2011 05:45 |
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues | VT_Bromley | FLUENT | 3 | February 12, 2011 09:02 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
