Home > Forums > FLUENT
Unsteady Convergence
Old   March 18, 2005, 23:50
Default Unsteady Convergence
Sham
Can some one pls tell me how to monitor for the convergence of unsteady problem. The residual will never go flat. Thanks.
Sham.
Old   April 3, 2005, 01:17
Default Re: Unsteady Convergence
swarup
unsteady state convergence should be obtained per time step if you are solving a unsteady state problem for incompressible flow (Ma<0.3). if you want a steady state solution from unsteday state simulation, then do not bother about convergence per time step. the number of iterations per time step (default 20) will be most likely sufficient for convergence once transients have died down. you will always see jumps in residuals at the start of a new time step. they will reduce once convergence is approached. you should try in addition to monitor a primitive variable or another quantity that you hope to see at a strategic point/area/volume of your choice. it is always better to check conservation law confirmations for physically meaningful solutions. residuals if are increasing then you better check their definition. when source terms are increasing scaled un-normalized residuals (default for FLUENT) keep increasing. it may very well happen that they are misleading you while your solution is under control. in my opinion, you should monitor many quantities instead of residuals only. a check of residual definitions will reveal something meaningful. regards, Swarup
Thread Tools
Trackbacks are On
Force can not converge colopolo CFX 13 October 4, 2011 22:03
unsteady convergence problem for bluff body Byukuya FLUENT 2 October 28, 2010 10:59
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Unsteady simulation convergence Tomislav Main CFD Forum 1 December 6, 2006 08:53
General Unsteady solution convergence Freeman Main CFD Forum 0 December 7, 2005 18:08
