Compiled UDF error
Old   March 19, 2005, 21:00
Default Compiled UDF error
ap
I'm writing a UDF to change the turbulent viscosity through a DEFINE_ADJUST macro.
DEFINE_ADJUST(turb_adjust, domain)
Thread *t;
cell_t c;
thread_loop_c (t, domain)
if (FLUID_THREAD_P(t))
begin_c_loop(c,t)
C_MU_T(c,t) = C_R(c,t)*C_MU*f_mu(c,t)*SQR(C_UDSI(c,t,TKE))/C_UDSI(c,t,TDR); /* Line 124 */
end_c_loop(c,t)
During compilation I get the following error:
LowReKE.c: In function `turb_adjust':
LowReKE.c:124: warning: use of conditional expressions as lvalues is deprecated
LowReKE.c:124: error: invalid lvalue in assignment
LowReKE.c:124: warning: use of cast expressions as lvalues is deprecated
make[3]: *** [LowReKE.o] Error 1
I tried to change line 124 to
C_MU_T(c,t) = 1.;
just to do a test, but the error massege is the same.
What does it mean? How can I change the turbulent viscosity in my domain in a UDF?
Best regards,
ap
Old   March 20, 2005, 07:54
Default Re: Compiled UDF error
Erica
I'm not sure what's wrong with your UDF, but firstly you can't separate the "thread_loop "and "{ " by the if(). When I use the FLUID_THREAD_P, some error occurred. I don't know why. (error : thread storage not implement)
Goodluck
Erica
Old   March 20, 2005, 09:26
ap
Thank you for your answer, Erica.
I tried to change the code as follows:
Thread *t;
cell_t c;
/* Set the turbulent viscosity */
begin_c_loop(c,t)
end_c_loop(c,t)
but the error is still there.
Looking in the UDF manual I saw the specific macro DEFINE_TURBULENT_VISCOSITY, but I'm not sure if it will work because I'm going to implement a new turbulence model, which will be solved instead of the FLUENT standard k-eps model, whose equation will be disabled in the Control -> Solution panel.
Best regards,
ap
Old   March 21, 2005, 01:42
Y
if you want I can try it on my computer cut and paste the code here. Y
Old   March 21, 2005, 06:11
Dirk
The DEFINE_TURBULENT_VISCOSITY should work with user defined scalars.
Old   March 22, 2005, 14:11
ap
Thank you. I tried with DEFINE_TURBULENT_VISCOSITY and it worked nice.
Regards, ap
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
