March 21, 2005, 04:52 |
Dynamic Mesh Needed?
Hi people!
I'm quite confused about the set up of my problem. WOuld appreciate some advice please. The flow scenario goes like this. 1. I have a small filter that's fixed in place within a vertical cylinder (attached to the wall). 2. The cylinder rotates about 2 axes - it spins about the vertical axis and tumbles about the horizontal axis. 3. The cylinder has an inlet and outlet. I need to study the flow within the filter as it rotates together with the cylinder. This is an unsteady flow problem, as I have an inlet and outlet flow together with the rotation of the cylinder. Now, do I really need to set up a dynamic mesh problem? Or can I just simply set rotation about the two axes in the boundary conditions and leave it at that? I need to look at the flow within the filter as the cylinder rotates. Thanks a million! Harmeet. |
Display Modes | |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Dynamic mesh in Fluent to study tire in contact with road surface | lihuang | FLUENT | 10 | March 8, 2011 10:21 |
Some questions about mesh updating in dynamic mesh technique | lzgwhy | Main CFD Forum | 0 | June 14, 2009 08:01 |
