Home > Forums > FLUENT
dispersion effect on disinfection calculations
Old   March 22, 2005, 13:46
Default dispersion effect on disinfection calculations
Mike Marcu
If somebody checked the effect of dispersion on uv disinfection in water-where the particles move and are irradiated with uv and consequently the microbes are genetically nudged in another direction.
I know that dispersion is playing a big role in chemical reactions and in heat transfer but in uv disinfection-may be not- because there we have essentially a trajectory and that is important-the position of the particle at a certain moment.
As you know dispersion is a function attached to trajectory usually resulting in huge txt files(Gigabites).
Thread Tools
Trackbacks are On
Turbulent dispersion of particle tracking in LES mittal OpenFOAM Programming & Development 4 February 23, 2011 19:01
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Question on Dispersion Mike Marcu FLUENT 2 September 14, 2005 19:53
dispersion effect on uv disinfection Mike Marcu Main CFD Forum 0 March 22, 2005 13:49
