K-Epsilon
Old   March 23, 2005, 23:07
Default K-Epsilon
Srivatsan V.R
I am Using K-Eslon Turbulnce modelling for a High Speed Compressible flow with combustion. Shd I use K-Epsilon General or any Modified K-Epsilon. If So, pls let me know the modifications, I have to make..
Srivatsan
Old   March 24, 2005, 01:30
Default Re: K-Epsilon
Fluent user
The K-E model works well for non combustion flows.First thing you must look at is thegeometry. The K-E model does not work well with flows in close proximity of walls and also the results depends on how good you can approximate your boundary conditions. For combustion Fluent has other models you might want to consider .
Cheers
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM Programming & Development 0 March 10, 2011 10:16
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 09:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
