Construct a three-sided surface in Gambit
Old   March 26, 2005, 04:49
Default Construct a three-sided surface in Gambit
User
I used to construct in Gambit the 3D four-sided face using the journal file
face create vertices "vertex.1" ..... ... "vertex.N" rowdimension Ndim
This generate my surface patches correctly.
Now I have some degenerate faces (e.g, three sided faces) but defined as a four-sided faces with coincident points (says the first row).
In this case gambit don't construct the face and prompts that some points are coincident.
The question is : How to construct the three-sided faces using this kind of definition ?
Thanks a lot
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Construct a three-sided surface in Gambit User FLUENT 0 April 12, 2005 08:39
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
Thin Surface in Gambit cfd guy FLUENT 2 August 16, 2001 12:47
