Fluent error while iterating
Old   March 26, 2005, 07:50
Default Fluent error while iterating
Pierre B.
first please excuse me for my bad english, i'm a french student.
my problem is the following : I need a great number of iterations to reach the convergence criteria. But after approx 1200 iterations i recieve the following error message :
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
what problem caused such a message ? how can i do to resolve it ?
thanks
Pierre
Old   April 3, 2005, 00:46
Default Re: Fluent error while iterating
swarup
Pierre, i also got this message while turning on FAS multigrid option in F6.1. i could not find answer for this problem although, the problem disappeared later on when i switched on FAS on F6.2. i suggest you report this to FLUENT support team. regards, Swarup.
Old   April 7, 2005, 13:39
Pierre B.
Thanks for your answer, my version is 6.1... Do you know links to get the 6.2 full version ?? thanks..
Old   April 7, 2005, 13:43
pUl|
Go to the User services center (http://www.fluentusers.com/fluent61/fluent61.htm) and check.
Old   April 8, 2005, 09:43
swarup
this error occurs when you want to access data that is not available with the code at that moment. somebody has posted this answer, i think.
questions of this nature have appeared previously also on this forum.
swarup.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
fluent error while iterating Ralf Schmidt FLUENT 9 July 21, 2006 09:17
