Heat transfer for fluid-fluid interface
Old   March 31, 2005, 15:25
Default Heat transfer for fluid-fluid interface
lentil
I defined flow of two fluids water and air in two regions. Fluent created "two-sided wall" and I choose "couple" option in BC for "two-sided wall". The problem is that in results there is no heat transfer. The temperature of air seems to have some gradient near wall but water has the same temperature as on inlet. if you have some suggestions please write regards
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Conjugated heat transfer interface pantarei83 FLUENT 0 October 5, 2010 03:52
Heat transfer in oil (or other high Pr fluid) flows vishyaroon STAR-CCM+ 0 April 14, 2010 11:52
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
