complex number operation in udf?
I want to use the complex number operation in udf, but udf has no this type of operation. Can I define the operation in it? and how? By the way, the operation inludes complex Bessel function. Thanks for your help.
Re: complex number operation in udf?
If you use compiled UDF, you can just use a C/C++ library which manages complex numbers.
There are many open sources solutions. For example, you could consider GSL. Best regards, ap |
You can find information on the GNU Scientific Library here:
http://www.gnu.org/software/gsl/ If you work on Linux, you probably just have to install it from the CD's of your distribution. Regards, ap |
Hi,ap,thank you very much! Now,my udf has been compiled successfully.
Dear HongXiao what did you do to complile your complex number udf?
Dear HongXiao what did you do to compile your complex number udf? I am trying to compile complex number udf but the "include<complex>" library does not compile in visual studio. So, which was you methodology?
