Skewness
Old   April 5, 2005, 07:21
Default Skewness
Taskin
hi, I have a 3D model that have high skewness values. However whatever I do for lowering skewness values didn't work. The worst element has a skewness of 0.82. What should the limits of skewness be for analyzing a turbulent flow of air around a body? is 0.82 anyway ok? Thanks Regards Taskin
Old   April 5, 2005, 07:29
Default Re: Skewness
dirk
I have read that maximum skewness value should be around 0.5.
Old   April 5, 2005, 07:42
Taskin
then I should decrease it in some way thanks Regards Taskin
Old   April 5, 2005, 08:32
handou
what? the max skewness should be 0.5? in my mesh ,it often exceeds 0.9. because i use dynamic mesh, sometimes over 0.95, and there will be a warning. so, i should remash it?
Old   April 5, 2005, 09:25
Luca
Yes, handou is right. The limit should be anyway 0.9 not to have excessive skewness. Luca
Old   April 6, 2005, 15:21
Riaan
From my experience, try to stay under 0.75.
Up to 0.85 is acceptable, but not good. Above 0.98 - and Fluent Grid check will fail.
Also when you use such skew cells, it makes sense to go to 2nd order methods for density, momentum etc.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
TGrid High Skewness khimkhim ANSYS Meshing & Geometry 1 February 17, 2010 23:36
problem with skewness jjchristophe FLUENT 1 January 14, 2010 21:22
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 18:47
Skewness & Decomposition Marc FLUENT 2 July 5, 2007 14:54
