UDF
Old   April 6, 2005, 02:44
Default UDF
Suvash
Hi How can I write a UDF of the boundary condition T(t)=Tm+Asin(wt), where T is the temperature, t=time, Tm=mean temaperature, A= amplitude=DeltaT/2, w=2pi/P=angular freequency, P=24 for the fluent....
Old   April 6, 2005, 05:10
Default Re: UDF
P
ITs very easy just check some examples in udf document. P
Old   April 6, 2005, 05:41
Default Re: UDF
Suvash
Hi P, Thanks for your advice. I wrote the following but could not getting the result.
#include "udf.h" DEFINE_PROFILE(Surface_hotflux_profile,t,i) { real x[ND_ND]; /* this will hold the position vector */ /* real xS; y direction */ /* real tempS; surface temperature*/
/* real Bi=1.; Biot number*/ real deltaTime=86400.; /* recycling time of day and night*/
real timeB=RP_Get_Real("flow-time"); real vt; face_t f;
if ( timeB<deltaTime) /*1 recycling*/
vt=timeB;
} if ( timeB>=deltaTime) /*2 recycling*/
vt=timeB-deltaTime;
if ( timeB>=deltaTime*2.) /*3 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*3.) /*4 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*4.) /*5 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*5.) /*6 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*6.) /*7 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*7.) /*8 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*8.) /*9 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*9.) /*10 recycling*/
vt=vt-deltaTime;
if ( timeB>=deltaTime*10.) /*11 recycling*/
vt=vt-deltaTime;
if ( vt>deltaTime/2.)
begin_f_loop(f,t)
/* tempS=F_T(f,t); get temp in surface */
F_CENTROID(x,f,t);
F_PROFILE(f, t, i)=290.+5.*sin(2*3.141592654*vt/deltaTime);
end_f_loop(f,t)
else
begin_f_loop(f,t)
F_CENTROID(x,f,t);
F_PROFILE(f, t, i)=0.;
end_f_loop(f,t)
Old   April 6, 2005, 06:58
Default Re: UDF
P
Do you get some error message then cut and paste them here in order for us to help u. P
Old   April 6, 2005, 23:57
Default Re: UDF
Sham
That's because you have not define sin function in the library. You need to write include math.h as well afer the include udf.h. This will define the sin function. Only UDF library is noy enough to recognise it.
Hope this help.
Sham.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
