Step-by-step approach in running unsteady flow in LES using Fluent |
December 2, 2013, 06:03 |
Taiwo
Rep Power: 14 |
Dear all,
Based on what I have gathered from various sources, please I want to know if the following is the correct step-by-step approach in running unsteady flow in LES using Fluent: 1. Start by running a steady state flow simulation using a Reynolds-averaged turbulence model such as standard - , etc. Run until the flow field is reasonably converged and then use the solve/initialize/ init-instantaneous-vel text command to generate the instantaneous velocity field out of the steady-state RANS results. 2. Run LES until the flow becomes statistically steady. 4. Continue until you get statistically stable data. 5. Zero out the initial statistics using the solve/initialize/init-flow-statistics text command. Before you restart the solution, enable Data Sampling for Time Statistics.Thank you. |
December 2, 2013, 06:10 |
Taiwo
Rep Power: 14 |
Dear all,
Based on what I have gathered from various sources, please I want to know if the following is the correct step-by-step approach in running unsteady flow in LES using Fluent: 1. Start by running a steady state flow simulation using a Reynolds-averaged turbulence model such as standard - , etc. Run until the flow field is reasonably converged and then use the solve/initialize/ init-instantaneous-vel text command to generate the instantaneous velocity field out of the steady-state RANS results. 2. Run LES until the flow becomes statistically steady. 4. Continue until you get statistically stable data. 5. Zero out the initial statistics using the solve/initialize/init-flow-statistics text command. Before you restart the solution, enable Data Sampling for Time Statistics. Thank you. |
October 24, 2016, 22:27 |
raunak jung pandey
Rep Power: 9 |
Did you succesfully perform LES ?
When using /solve/initialize/init-instantaneous-vel while carrying out LES i am getting the error Error : (segmentation fault) Error Object : #f What could be the problem ? How to solve it ? " |
October 25, 2016, 03:48 |
A segmentation fault usually means that some memory location has been accessed (i.e., a variable) but that wasn't present. In practice, it is probable that you forgot to make some of the steps necessary to follow the procedure. Maybe:
1) Perform the preliminary RANS calculation (i don't remember if a specific RANS model is needed) 2) Activate LES after the RANS or maybe you did something that erased the previous RANS solution. |
Transient flow in fluent | linyx | FLUENT | 15 | April 24, 2013 09:54 |
Split boundary zone in FLUENT for mass flow | eishinsnsayshin | FLUENT | 1 | January 18, 2013 13:43 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Unsteady flow in FLUENT | Vidya Raja | FLUENT | 2 | November 2, 2005 16:29 |
Unsteady Flow in FLUENT | Vidya Raja | FLUENT | 0 | November 1, 2005 17:54 |
