March 26, 2005, 07:50 |
Fluent error while iterating
first please excuse me for my bad english, i'm a french student.
my problem is the following : I need a great number of iterations to reach the convergence criteria. But after approx 1200 iterations i recieve the following error message : Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () what problem caused such a message ? how can i do to resolve it ? thanks Pierre |
April 3, 2005, 00:46 |
Re: Fluent error while iterating
Pierre, i also got this message while turning on FAS multigrid option in F6.1. i could not find answer for this problem although, the problem disappeared later on when i switched on FAS on F6.2. i suggest you report this to FLUENT support team. regards, Swarup.
April 7, 2005, 13:39 |
Thanks for your answer, my version is 6.1... Do you know links to get the 6.2 full version ?? thanks..
April 7, 2005, 13:43 |
Go to the User services center (http://www.fluentusers.com/fluent61/fluent61.htm) and check.
April 8, 2005, 09:43 |
this error occurs when you want to access data that is not available with the code at that moment. somebody has posted this answer, i think.
questions of this nature have appeared previously also on this forum. swarup. |
Display Modes | |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
fluent error while iterating | Ralf Schmidt | FLUENT | 9 | July 21, 2006 09:17 |
