-   -   Under-relaxation factors (http://www.cfd-online.com/Forums/fluent/36320-under-relaxation-factors.html)
pUl| April 8, 2005 17:35
I know that a converged solution is independent of the value of URF's chosen. However, is it acceptable to change URF's in the middle of a solution and then continue iterating?
ap April 9, 2005 07:49
Re: Under-relaxation factors
Yes it is acceptable.
You're right when you say that a converged solution does not depend on the value of URF's, but the convergence of a solution is dependent on their values, and also by the combination of them.
Some authors like Peric, for example, suggests some rule of thumb like
a_velocity + a_pressure = 1
where a represents the URF.
Regards, ap
swarup April 9, 2005 10:22
regarding URF's,can excessive under-relaxation introduce accuracies in unsteady flows. that is, although solution will be converged but not accurate?
Swarup.
pUl| April 9, 2005 13:55
Thanks Swarup, You meant "introduce inaccuracies" right?
pUl| April 9, 2005 13:56
Thanks for the information ap. Very well worded indeed!
