Home > Forums > FLUENT
Brinkman-Forchheimer equation
Old   April 9, 2005, 17:12
Default Brinkman-Forchheimer equation
abdul
Dear All,
How can I model a porous medium in Fluent by using Brinkman-Forchheimer equation.
Many thanks,
Abdul
Old   April 10, 2005, 09:50
Default Re: Brinkman-Forchheimer equation
Amir
If you mean equation 2.143 of Kaviany's book. What I did, I multiplied both sides of the equation with porosity factor and updated the source terms and calculated them accordingly.
Amir
Old   April 10, 2005, 13:07
abdul
Dear Amir,
Could you be more specific, or can you direct me to a published on the approach you indicated.
Many Thanks,
Abdul
Old   April 10, 2005, 13:22
Amir
ok, I have been working on the same subject in my thesis and I found out there are different interpretations on Brinkman-Forchheimr equations. Some researchers use an extra porosity factor in the denominator of the convection term (Neild and Bejan) and some not (Vafai and Kaviany). I personally use the work of Vafai and Kaviany. I give you a couple of publications by them at the end of this message. Take a look at them and see if you still have problem with the form of the equaitons and then I will conduct you to how implement that into FLUENT.
Amir
1. Kaviany, M., 1991, Principles of Heat Transfer in Porous Media, Springer-Verlag, New York.
2. Vafai, K. and Tien, C. L., 1980, "Boundary and Inertia Effects on Flow and Heat Transfer in Porous Media," International Journal of Heat and Mass Transfer, 24, pp. 195-203.
Old   April 14, 2005, 11:27
abdul
Yes, I still have problem with the form of the equaitons. Please, show me how to implement that into FLUENT.
Regards,
Abdul
Old   April 16, 2005, 12:33
Amir
Well, if you are convinced to use the form of equation recommended by Vafai and Chen, you can easily multiply both sides of the equation by porosity factor. then the momentum equation solved by FLUENT would be as close as possible to the form of Brinkman-Forchheimer equation presented by Vafai and Kaviani. you just need to treat the source terms properly which I beleive would be as following:
C1 = mu*epsilon/K
C2 = rho*F*epsilon^2 / K^.5
in which mu = density
K = permeability
rho = density
epsilon = porosity factor
F = Forchheimer coefficient
and F = 1.75/sqrt(150*epsilon^5) based on the packed bed model
Hope it helps Amir
Old   April 17, 2005, 16:22
abdul
Thank you Amir
Old   July 2, 2010, 04:20
psb
PSB
psb is on a distinguished road
Hi Amir,
I am having the exact same problem in modeling Vafai's equation in Fluent. Your answer is indeed very helpful.
However, I have a question: What do you do with the pressure gradient term on RHS? If we multiply that too, by porosity factor, the solution diverges. Is it good to neglect multiplication to pressure gradient term, and multiply all the other terms with porosity? Will this give huge errors?
psb is offline   Reply With Quote
Old   November 8, 2011, 22:52
Default Requests for help
Yongsheng Tian
Yongsheng is on a distinguished road
Originally Posted by Amir
;119778
C1 = mu*epsilon/K
K = permeability
rho = density
Hope it helps Amir
Dear Amir
I am trying to model a porous medium in Fluent by using Brinkman-Forchheimer equation. I am a Chinese students, so I have a difficulty to find that publication that you mentioned:Vafai, K. and Tien, C. L., 1980, "Boundary and Inertia Effects on Flow and Heat Transfer in Porous Media," International Journal of Heat and Mass Transfer, 24, pp. 195-203.
So I need your help, the more specific. Thanks a lot.
Best wishes!
Yongsheng is offline   Reply With Quote
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
continuity equation Rafal Main CFD Forum 4 November 29, 2006 10:27
