Problem with prePDF
Old   April 15, 2005, 13:15
Default Problem with prePDF
gautam
hi there i tried to generate the required pdf file of the fuel(LSHSD) for non premixed combution model of my combustor. the max temp it is showing is 5500k which seems to be absurd . i am following the guide lines of the help files on coal combustion, ie equilibrium model , beta solver etc.(basically i am using the default vales). the species are C,H,S,O2,N2,CO2,CO,C,O,H2O,HO,SO2. C=.353 H=.646 S=7.4e-04. so the final analysis in fluent is giving an exit temp of 4400k . more over is it necesarry to model the swirler the igniter for the GT combudtion chamber. could any one kindly tell what could the problem be. thank u.
Old   April 24, 2005, 11:59
Default Re: Problem with prePDF
abel
hello!
try to use firstly adiabatic case unser prepdf, note the peak temp and the coreponding mixture fraction, then run the non adiabatic case, you can see details on the tutorial"modeling non premixed combustion" of the fluent 6.0
A+
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
