March 4, 2007, 22:38 |
Reverse rate parameters with CHEMKIN imports
I am trying to run a combustion simulation of dimethyl-ether (DME) in FLUENT using chemical kinetics files from CHEMKIN. However, when I attempt to import the files, FLUENT gives me an error that it cannot handle reverse rate parameters. It is my understanding that these are Arrhenius rate coefficients given for reverse reactions that do not relate to the forward reaction rate through the equilibrium constant of the reaction. I was wondering if anyone has used FLUENT with kinetics files that have reverse rate parameters specified. Right now we do not have a license for the KINetics module in FLUENT. Is that needed to use reverse rate parameters? Thank you for any help.
June 27, 2013, 04:22 |
Roberto Meloni
Rep Power: 13 |
Hi Kevin,
Have you fixed your problem? I have the same error when I try to import biodiesel Chemkin Mechanism. All the best. Roberto. |
Display Modes | |
CFX12 rif errors | romance | CFX | 4 | October 26, 2009 13:41 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
Chemkin reader TROE parameters | stefanke | OpenFOAM Running, Solving & CFD | 1 | September 9, 2006 00:02 |
Rate equation parameters for Hydrogen combustion | Hernandez | Siemens | 2 | September 27, 2005 13:33 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
