compiled UDF
Old   April 19, 2005, 14:16
Default compiled UDF
Jiri Novak
I try to compile a UDF. I put the *.c file and udf.h file in the same directory as the *.cas file. There is no other *.h file created by myself. When I click "build", it creates the directory and copy a few files in that directory, but when click "load" it give me an error message saying "Error: open_udf_library: The system cannot find the file specified."
(WIN ntx86 technology for running my Fluent v6_1_18)
Thanx a lot for help...
Old   April 19, 2005, 19:43
Default Re: compiled UDF
pUl|
1. You have a space in your file name (E.g. "my udf.c")
Take it out. User underscore (_) instead.
OR
2. You work in a directory like "C:\Documents and Settings\Username\"
Try to work in a folder created in the root portion of a drive like C:\CFD or D:\MYFILES\CFD
Try avoiding spaces.
Old   April 20, 2005, 03:21
Ale
Try writing the full path of the directory in the "Library name" field. (e.g. C:\myfiles\cfd\libudf)
Regards,
Ale
Old   April 22, 2005, 18:04
Saad
Just a reminder: Visual C++ should be installed on the computer for compiling the udfs.
Sincerely,
Saad
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 12:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 14:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 00:04
how to quit compiled or interprited UDF tian FLUENT 0 April 8, 2003 23:53
