April 19, 2005, 02:13 |
problem for UDF velocity
I have a problem of numerical diffusion (I think but I'm not sure) when I postprocess an UDF for the velocity (for Vx and Vy). In fact, the angle velovity is not the same at all (on each edge) when I test it on a simple geometry like a rectangle.(putting a pressure far field on each edge)
My goal is to simulate the flow around an oscillating profile in order to test the different turbulence models on Fluent....do you think it will be better to create a dynamic mesh and make the profile move instead of the wind velocity in the boudary conditions? Thank you very much for your time. |
Velocity field problem | feizaghaee | CFX | 20 | February 24, 2010 04:23 |
velocity problem | phy | FLUENT | 1 | February 8, 2008 17:12 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 06:47 |
Velocity scale for Broken Dam Problem | Valdemir Ferreira | Main CFD Forum | 0 | June 3, 2005 08:01 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
