Home > Forums > FLUENT
Patch
Like Tree1Likes
  • 1 Post By Weis
Old   April 21, 2005, 11:10
Default Patch
Weis
How to make a patch in a gap between coaxial cylinders ? Thanks for your help!
Old   April 21, 2005, 11:33
Default Re: Patch
aPpA
Mark the region you want to patch using the Region Adaption tab (Adapt-> Region).You will be able to select the shapes in region adaption window. Once you initialize the solution, the Patch tab will be higlighted. (solve->initialize->patch)
Old   April 21, 2005, 12:00
Default Re: Patch
Weis
Hi, APpA
Thank you for quick response. I mean how to make a region like a gap between two coaxial cylinders.
Old   April 21, 2005, 15:08
Default Re: Patch
aPpA
Its the same way..except that you select Cylinder instead of Hex or sphere in the Region adaption window. input the min and max coordinates and the radius of the cylinder. You can also do this by clicking on the "Select Points With Mouse" tab and select the points manually. If u do this u will need to select three points. cheers!
Old   April 21, 2005, 16:47
Default Re: Patch
Weis
Thanks again, but I need the region which lies between two cylinders. You can do it separately and get two marked cylinders . How can I substract one from another in the Adaption operation? Maybe I did not understand what you mean. Can you do it step by step for me? Thanks
Old   April 21, 2005, 19:24
Default Re: Patch
aPpA
Hi., this is how its done by me usually., I "split" both the co-axial cylinders while creating the geometry in gambit, that makes the two cylinders to be one unique geometry.Then define the boundaries as required. Once the msh is exported, read it and initialize the case. Adapt->Region-> select Cylinder in Shapes Enter the min & max coordinates as shown below (for example two cylinders of radius 0.025 and 0.05 with height of 1 m are present)
Min Max X 0.025 0.05 Y 0 1 Z 0.025 0.05 Enter the value for radius Make sure the "inside" tab is marked so that the cells with in the region will be marked. Once this is done then press "Mark" Now patch it. Hope this clears it up...?
Old   April 22, 2005, 00:42
Default Re: Patch
Weis
Thanks for your answer, but in this CASE what value of the radius was be input ? There are two choice. One is 0.025, another is 0.05. Only one can be choosen. I am still confused.
DILIPKUMARGARG likes this.
Thread Tools
Trackbacks are On
Using starToFoam clo OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 33 September 26, 2012 04:04
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
