help: solid + gas
Old   April 22, 2005, 03:16
Default help: solid + gas
Mihai
Hy! Is it possible to create a double flow with heat exchange: solid (rocks - d=0.11m - gravitational) and air, in the same volume? It would be much help!
Mihai
Old   April 22, 2005, 08:18
Default Re: help: solid + gas
ap
You can model gas-solid flows with heat exchange in FLUENT 6.1 and 6.2. See the Eulerian model.
Regards,
ap
Old   April 25, 2005, 03:51
Mihai
Thank you for your response! i tried that, but i have this unswer when i initialize the solution: "fluent 6.2.16 recived a fatal signal (SEGMENTATION VIOLATION)". i think is becouse the dimension of the solid pfaze is to big (0.11 m), but it can be that i am wrong. Do you know more about this? Regards, Mihai
Old   April 25, 2005, 08:03
ap
Well, I'm not that sure that the kinetic theory is still valid for such a big pieces of solid. I seriously doubt it.
I'm not sure of the reason of FLUENT error message however.
Best regards,
ap
Old   April 25, 2005, 09:30
Mihai
Thank you for your response! I'll try to find another way. Mihai
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 16:53
