April 22, 2005, 05:38 |
More Error Messages
Hi, what about these Error Messages? Do you know what do they exactly mean? Any clue?
Thanks a lot! Ale Primitive Error at Node 0: floating point exception Primitive Error at Node 1: floating point exception Primitive Error at Node 1: Cell_Function_Values: unrecognized function: uds-0-scalar Primitive Error at Node 0: Cell_Function_Values: unrecognized function: uds-0-scalar Error: Unknown object encountered in garbage collection Error encountered in critical code section Error: Unknown object encountered in garbage collection Error encountered in critical code section Process [0] exited with status [1] Process [1] exited with status [1] MPIRUN exited with status [0] Error: floating point exception Error Object: #f 999999: mpt_write: error: write failed trying to write 8 bytes: No such file or directory The Parallel FLUENT process could not be started. |
April 22, 2005, 07:38 |
Re: More Error Messages
If you're using a UDF in your case, check it. It is most likely not parallelized properly.
