reversed flow???
Old   April 24, 2005, 11:51
Default reversed flow???
abel
Hello! I am looking for the meaning of "reversed flow" message, it appears(when iterating) during the fluent calculation, is it related to the inlet(operating) conditions? does it affect the solution precision? numerical or physical sens?
thanks.
Old   April 24, 2005, 16:46
Default Re: reversed flow???
Harish
Reversed flow implies a boundary layer separation , the flow velocity changes direction. In some calculations like say the flow past a cylinder the flow is reversed.It occurs when the pressure gradient changes sign.
-H
Old   April 25, 2005, 01:48
Mehdi Ghoddosy
Dear Abel: FLuent assumes developed flow for some types of inbuilt boundary conditions such as outflow. Hence you should place your boundary in a place that flow is fully developed and no reverse flow exits, otherwise the mass consevation equation would not satisfy and solution convergence fails. The reverse flow alert would be shown if you have any type of reverse flow such as boudary layer separation befor boundary. Regards Mehdi Ghoddosy
Old   April 29, 2005, 04:54
kiran
hi mehdi for compressibleflow, outflow condition is not valid,in such cases pressure outlet is works. but in nozzle flow for getting exact mach numer we should specify pressure at outlet.do uhave any idea about convergence of species transportation problem in nozzel?
regards kiran
reversed flow free FLUENT 4 February 27, 2014 01:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
