Home > Forums > FLUENT
face meshes
Old   April 29, 2005, 08:09
Default face meshes
zeynep
I have a question. To have a continuous mesh on the two faces, the faces should come together (for a connection)
1) the easiest way to do for a 3D model? 2) if these two faces are real and non real, how may I connect the meshes?
thanks,
Old   April 30, 2005, 08:33
Default Re: face meshes
Mehdi Ghoddosy
Dear Zeynep: You can create your model in separate files in gambit. then merge these files using "tmerge" utility. Next you have to set grid interfaces in fluent for computing non-conformal mesh interfaces to hold on continuty equation, If u think these procedure solves your problem contact me for more information. Regards
Old   May 2, 2005, 01:05
zeynep
Dear Mehdi, thanks for your reply. Actually my problem is on the model. Some of the model has real, some has non real faces. I have to do surface mesh. after I complete the mesh, I have to put it into a wind tunnel and mesh the wind tunnel (volume mesh) and then connect the face meshed model with the volume meshed wind tunnel to hold on continuity. how is the easisest and quickest way to do this kind of an application using Gambit?
Old   May 2, 2005, 01:42
Mehdi Ghoddosy
Dear Zeynep:
If you persist to connect face and volume meshes using conformal meshes in gambit, it would be too difficult and time consuming(depending on your model). In this way using two sided faces can help you. But i recommend you to use non-conformal mesh. In non-conformal meshing procedure you are not forced to connect volume and face meshes. Just define an face between mesh and volume and then in fluent define this as grid interface. Best regards
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
