Error when compile UDF file
Old   May 1, 2005, 17:32
Default Error when compile UDF file
Lee
Hi, I tried to compiled UDF file and it gives me this error: 'nmake' is not recognized as an internal or external command, operable program or batch file
Any solutions? Thanks in advances
Lee
Old   May 1, 2005, 22:52
Default Re: Error when compile UDF file
pUl|
Do you have MSVC installed and the ENVIRONMENT/PATH set correctly?
Old   May 2, 2005, 12:54
Lee
Thanks for response. Where can I get MSVC? How to set ENVIRONMENT/PATH? Thanks
Old   May 3, 2005, 06:43
Manolito
I think you have to install a C compiler. I had the same error so I installed Microsoft Visual C++ and the problem go away
Old   May 3, 2005, 06:52
Luca
Yes, you need MSVC and when you install it enable the panel "set-environment variables". Maybe I'm wrong bui you can download it from MS web site. Give it a look. Luca
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
