variable diffusivity
Old   May 1, 2005, 15:04
Default variable diffusivity
co2
I am solving gas diffusion equation using fluent 6.1. I have a porous media and fluid domain next to each other. There is no force convection and velocities are mainly due to diffusive forces in the model. I am using mixture template to model species transport. I want to turn off flow equations to get quick results, but doing that will make the momentum sink terms in porous media model go to zero when flow equations are not solved. To still get the resistance to diffusion in the porous medium, I will like to mass diffusion coeff in the porous medium as compared to the fluid medium. How do I do that. How do I make the mixture template use one value of mass diffusivity in one domain and a different value of mass diffusivity in a different domain. The values wont change with time. Do I need a UDF to do this? Please guide. Thanks in advance.
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Additional Variable - Diffusive Transport Equation RadheShyam Das CFX 3 October 18, 2007 12:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
