April 30, 2005, 12:03 |
what's the meaning
> Reading "D:\BUBBLE.GRD"...
Building... grid, Error: Null Domain Pointer Error Object: () I use the fluent6.2,i cann't go ahead. |
May 1, 2005, 22:17 |
Re: what's the meaning
it seems to me that the file u r reaidng is old format file and probably needed to be converted to new format of fluent6.
May 2, 2005, 00:58 |
Make sure the solver option is set to fluent 5/6 in gambit.
-H |
May 3, 2005, 03:13 |
This is FLUENT 4 Grid file. you must have selected FLUENT 4 while assigning boundary zones to your geometry in GAMBIT.
Are you following Fil-->Read--->Case option? you may get this error in that case. You should follow the path File-->Import-->Fluent 4 |
May 3, 2005, 07:34 |
3ks,it's ok following your advice.
Physical meaning of pressure in pressure eqn | dontknow | Main CFD Forum | 2 | August 30, 2010 10:12 |
What's meaning of UDF FUNCTION | zhaoxinyu | Fluent UDF and Scheme Programming | 0 | March 31, 2010 08:04 |
what is the meaning of patching | shyam | FLUENT | 1 | July 29, 2008 06:25 |
want to know meaning | Sangamesh | Siemens | 0 | May 15, 2007 05:15 |
What's the meaning of "combustion scalar"and.... | cfdbeginner | CFX | 0 | November 27, 2003 09:02 |
