Dynamic Pressure
Old   May 25, 2005, 06:07
Default Dynamic Pressure
Mahmood
Hi
I am solving an external flow problem. When I plot the values of dynamic pressure along the wall, it results in nonzero values. According to no-slip B.C. on the wall the velocity component must be zero, thus zero dynamic pressure!
What's up?
Old   May 25, 2005, 06:38
Default Re: Dynamic Pressure
Mehdi Ghoddosy
I guess that you have to check your wall function and yplus. Dynamic pressure should be zero at the wall but increased very rapidly near the wall and then decreases. Also are you sure that your first point exatcly is on the wall? just inn the point of y/delta=.0001 the dynamic pressure has large values.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Question about the dynamic pressure in the lifting/drag coefficients tenkio Main CFD Forum 1 May 17, 2011 11:23
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
FLOW AROUND A PLATE_NEGATIVE ABSOLUTE PRESSURE???? tania FLUENT 11 March 23, 2004 08:51
