Modelling combustion and heat transfer
Old   April 23, 2005, 14:43
Default Modelling combustion and heat transfer
Tudor
How can I simulate the combustion using a pdf mixture and, in the same time, the heat transfer between the exhaust hot gases and water through a wall? I ask this because when you have a pdf mixture for non-premixed combustion in Fluent 6.2 you can't use a massflow-inlet of a fluid that isn't a part of the mixture, like liquid water. If there is a solution please let me know! Thank's!
Old   April 24, 2005, 03:31
Default Re: Modelling combustion and heat transfer
kiran
Old   April 27, 2005, 10:55
lesmqn
Did not quite get your Question. Can you explain a little more?
Old   May 1, 2005, 09:08
cg
You could possibly use the two mixture fraction PDF model, with the second mixture being water. However, it might be better to use the ED model instead.
Old   May 9, 2005, 07:02
Ehsan
Hi; To what extend chemistry is important in your case?It is quite better to switch from PDF to EDC if the reduced mechanism is available.Please let me know what sort of fuel are you using for your simulation. Regards
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
