-   -   Fluent like public domain program (http://www.cfd-online.com/Forums/fluent/36614-fluent-like-public-domain-program.html)
Senol Piskin May 10, 2005 06:26
I heard recently that a program similar to Fluent is public and open source. Have you heard such a program?
Luca May 10, 2005 06:27
Re: Fluent like public domain program
Search for OPEN FOAM .Luca
michael May 10, 2005 07:36
Is it possible to run Open Foam on Windows machine ?
Luca May 10, 2005 07:37
no I don't think. Have a look on open foam forum or site
Anindya May 10, 2005 18:29
Might try loading Cygwin on windows and then install FOAM.
michael May 11, 2005 03:31
OpenFoam
I'm am very interested in OpenFoam. Has anybody validated this code? Compared with fluent? What are your experiences with using OF?
mystic_cfd May 12, 2005 00:28
Re: OpenFoam
Why don't you try the website at:
http://www.opencfd.co.uk/openfoam/
There will soon be a separate forum for OpenFoem here as well!
ap May 16, 2005 18:57
Re: OpenFoam
It a very good code. Not as easy to use as FLUENT, but it's far more versatile, if you need to add your user defined models because you have full access to the source code.
Best regards,
ap
ap May 16, 2005 18:59
No. OpenFOAM works on Linux ;-)
However there is a discussion about ports on Windows and Mac on the forum hosted at
www.openfoam.co.uk
Best regards,
ap
Diaperboy Sux May 18, 2005 02:03
OpenFoam on windows
well you can run OpenFoam on windows under a virtual machine with Linux installed on it, you can try workstation 5 from VMware, Usually I do the other way, on a linux machine a run windows on a virtual machine, that works pretty well. The only problem is that it takes a very good hardware to do the job.
DS
Diaperboy Sux May 18, 2005 02:06
MFIX for multiphase
Other really good tool, multiplataform and open source people from fluent are working in this project also.
http://www.mfix.org/
DS
