Question on heat transfer coefficient!!!
Old   May 11, 2005, 23:59
Default Question on heat transfer coefficient!!!
Benny
Dear All,
Now I have a question on heat transfer The problem concerned is simple: there is a straight circular duct, water flows through the duct, and heat flux loads on the duct's wall. What I want to know is heat transfer coefficient. But I found the results of the calculation are not correct at all comparing with results obtained from the formula: h=Nu*conduct/d, where h is heat transfer coefficient, Nu is the Nusselt number, conduct is thermal conductivity and d is the diameter of the duct. In the Fluent help document, I found that Surface Heat Transfer Coef. is defined by h=q/(T_wall-T_ref), where q is the heat flux, T_wall is the wall temperature and T_ref is the reference temperature which means the average temperature of the fluid. The default value of the T_ref is 288.16K. But I think maybe in different conditions the T_ref is different, so I change it to the average temperature of the fluid. My question is: Is that right to do so and could I get the correct heat transfer coefficient by doing so?
Best regards!
Benny
Old   May 12, 2005, 15:49
Default Re: Question on heat transfer coefficient!!!
Thomas
Yes, you are right by doing so. Actually you should set this T_ref to the fluid temperature close to the wall, where you want to know the htc. Or, you could also use the htc in your turbulence modell.
Old   May 12, 2005, 21:52
Benny
Dear Thomas,
Thank you very much for your answer. But how could I get the average fluid temperature close to the wall? For I want to know the htc distribution on the whole surface of the wall. And what does this mean: Or, you could also use the htc in your turbulence modell? Thank you again for your time!
Best wished!
Benny
Old   May 16, 2005, 02:23
Balaji
hi,
the htc is between wall temperature and bulk temperature. Bulk tempereature can be calculated using mass weighted average of temperature.I think if you use this you will get it.
Balaji
Old   May 16, 2005, 08:41
Benny
Dear Balaji,
I want to know what the bulk temperature is? I can get it as your advices, bu where to change its value? I appreciate your help if you could give me some advices in details.
Benny
Old   May 20, 2005, 00:19
Balaji
hi,
Bulk temperature we can calculate by Mass weighted average Temperature. This we can get from surface integrals. I don't know whether we can use this value directly to calculate the HTC.One thing is we can write a udf to calculate Bulk Temp and wall Temp at given locations and get HTC.
Balaji
Old   May 28, 2005, 20:09
seirov
Hi!
I am studying a similar problem, but with a external flow. I am not a english spoken person, and I don't know what is the meaning of bulk temperature, but in my case, the reference temperature is the inflow temperature (temperature defined in the velocity inlet boundary conditions) and not the average temperature, as you say. And I think internal flow is the same.
Good luck!
Old   June 7, 2005, 09:25
Mahesh
Then if you are calculating HTC based on Inlet Temperature, give the same in Reference panel and using Contours--> wall Fluxes, u can plot/get the HTC.
Distribution of surface heat transfer coefficient along the axial direcion of a tube andred FLUENT 0 November 16, 2010 21:13
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
