Asking for help! Thanks a lot!
Old   May 14, 2005, 01:59
Default Asking for help! Thanks a lot!
Yang Bin
Dear all:
This problem is focused on heat exchanger in typical air-conditioning system. I want to know whether the latent heat transfer caused by condensating of moist air can be coupled with sensible heat transfer in simulation successfully? I want to simulate the whole process when moist air come through the cooling coil in both air side and water side.
I have asked this question for several times. Please help me if you have some experiences in this filed. Thank you very much!
Yang Bin From Singapore
creating surfaces from lot of xyz data rolando guerrieri Fidelity CFD 3 February 26, 2016 13:43
temperature wit a lot of decimal points - Celsius rogbrito FLUENT 0 February 7, 2010 17:01
create a lot of points payam_IUST FLUENT 2 October 13, 2009 15:58
Very interesting and beautiful site. It is a lot o Pantelis FLUENT 0 October 26, 2007 02:27
Asking for help! Thanks a lot! Yang Bin Siemens 2 May 16, 2005 06:24
