-   -   Creating an animation (http://www.cfd-online.com/Forums/fluent/36683-creating-animation.html)
Jason May 17, 2005 12:06
I have a surface sweep and I want to save this as an animation so I can send it to someone, but I can't figure out how to do this. Is it even possible to save an animation for a surface sweep? If not, does anyone have any tips or tricks on how I might be able to create an animation like this and save it to an mpeg (or avi, or whatever...)
Thanks in advance, Jason
venugopal May 18, 2005 00:39
Re: Creating an animation
Yes, You can make animation interms of movie. In fluent animation option is there (Display/Animation). But it will not give smooth movement of the animation. Another shortcut method is writing commands in Solve/execute commands.. In that one you can write commands so that you can save a jpg file for each iteration/timestep of your required contour and finally you can attach all the files. By using this method you can make movie of any controur or any vectors without applying much efforts. See this below link for further idea.
http://www.fluent.com/about/news/new...00v9i2/a23.htm
VenuGopal. S
rom May 18, 2005 04:23
The best option to create avis for me is to use the animate panel to create a series of pictures (hardcopies) and merge them with makeAVI (freeware, see http://makeavi.sourceforge.net/). This way you can specify a framerate and avi-codec for your video.
good luck rom
zxaar May 18, 2005 05:13
i sent a mail, check ur inbox
