help me for dynamic mesh
Old   May 17, 2005, 21:44
Default help me for dynamic mesh
speedcat
Hi I'm having trouble getting the UDF DEFINE_GEOM to work properly. I would like to use the UDF to make the bottom of a rectangular duct with air blowing deform into a different shape over time. I have compiled the UDF properly and have hooked it into fluent as outlined in the UDF user's manual. However, when I view the mesh motion, the bottom does not deform.
I'm having trouble getting the UDF DEFINE_GRID_MOTION to work properly, too. I have compiled the UDF properly and have hooked it into fluent as outlined in the UDF user's manual. However, when I define the zone of the dynamic mesh, an error of ˇ°incorrect geometry udf gg on zone 6 (assuming no geometry )ˇ±. The bottom is zone whose ID is 6.
I would really appreciate your help. My e-mail is sxy_hit@163.com
My project is shown as follow. I will give you some file about my problem and the UDF of DEFINE_GEOM and DEFINE_GRID_MOTION.Thank you!
The bottom of the duct is from (-5,-2.5) to (-5,2.5). the new position is defined by a parabola through (-5,-2.5), (0,-2.4) and (-5,2.5). The parabola is
DEFINE_GEOM:
/************************************************** *** * * defining parabola through points (-5,-2.5), (0,-2.4),(5,-2.5) * ************************************************** ***/ #include "udf.h"
DEFINE_GEOM(parabola,domain,dt,position)
/*set y=-0.004x^2-2.4*/
position[1]=-0.004*position[0]*position[0]-2.4;
DEFINE_GRID_MOTION
DEFINE_GRID_MOTION(gg, domain, dt, time, dtime)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *v;
int n;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop (f, tf)
f_node_loop (f, tf, n)
v=F_NODE (f, tf, n);
if (NODE_POS_NEED_UPDATE (v))
NODE_POS_UPDATED (v);
NODE_Y(v)=-0.004*NODE_X(v)*NODE_X(v)-2.4;
end_f_loop (f, tf);
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
