3CPU vs 2CPU
Old   May 18, 2005, 03:35
Default 3CPU vs 2CPU
M.
Hi, I prepared a Moving Mesh problem with UDF, and it runned well under 2 CPU. I wanted to try to run it under 3 CPU, but it failled as I import the *.cas file, here is the error message:
Hex-core Mesh: 27 encapsulated cells, 1140 parents, 4560 child faces Primitive Error At Node1: Cannot locate child -151743 in new face 1488190
I don't understand why it runs under 2 CPU and not under 3 CPU. Any idea? Thanks Maxime
Old   May 18, 2005, 04:12
Default Re: 3CPU vs 2CPU
zxaar
i think the cure for this would eb this, u can read the mesh on single processor machine, and do the manual partioning for three processors, save the case data files and read them in three processor.
should work
Old   May 18, 2005, 04:18
M.
Hi, Already tested, but doesn't work. It returns the same message
Old   May 18, 2005, 04:27
M.
ok it works, but I had to disable the Encapsulate Grid Interface toogle Thanks!!!
Help: Batch file for Parallel Processing ( 2CPU ) SC FLUENT 1 July 15, 2003 21:34
